Hi Olleg, Congratulations.
Is there any way to delete all files from a folder that is located in multiple locations?
With just one command? For example:
C:\Test\Videos\Temp\heart.mpg
C:\Test\Windows\Temp\audio.mp3
How can I delete only the files from the temp folder, with just one command?
Delete all files from a folder that is located in multiple locations? One Command
anthonyystwarty
Re: Delete all files from a folder that is located in multiple locations? One Command
You can add multiple folder and file, it will create a directory list
anthonyystwarty
Thanks for the answer, yes, I use this, but I would like to not need to add all the folders to be deleted, I need something like a command that searches all the \Temp folders that are in C:\ and deletes all the files.
Congratulations
Congratulations
In this case you must search all folders named Temp in the File Loop.I need something like a command that searches all the \Temp folders that are in C:\ and deletes all the files.
Use "By folders only" option.
And delete the necessary files inside the loop in every folder you find.
anthonyystwarty
Hello Oleg, How are you? Unfortunately I couldn't do it, because I didn't understand how it works due to my language, could you help me?
Does Fileloop delete files? Sorry for the inconvenience.
- Attachments
- Screenshot_1.png (24.79 KiB) Viewed 147766 times
Look at this example below.
then you can see in in task editor
The task searches for TEMP subfolders in some StartFolder folder and deletes files in the found folder.
CatID=INTEGER|1075658632
ExternalName=STRING|"Task1455"
ID=INTEGER|-1167522676
Name=STRING|"Remove files in TEMP subfolders"
StepPause=INTEGER|0
Name=STRING|"Set variable ""StartFolder"" with value ""C:\test"""
_rt_variables_produced=STRING|"StartFolder"
varname=STRING|"StartFolder"
varvalue=STRING|"C:\test"
Name=STRING|"File Loop // Looking for TEMP subfolders"
_rt_variables_produced=STRING|"FolderToClear"
date1=STRING|"20241003"
date2=STRING|"20241003"
destvar=STRING|"FolderToClear"
DuringMinutes=STRING|"1"
file0=STRING|"{StartFolder}\temp"
searchkind=STRING|"1"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"1"
timesize=STRING|"0"
message=STRING|"clear folder {FolderToClear}"
Name=STRING|"Delete File // delete file in TEMP subfolder"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"{FolderToClear}\*.*"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
anthonyystwarty
Thanks a lot for your assistance, you're always so helpful! The command worked now, that’s exactly what I needed!
Thank you for giving us that experience. We hope you will share more with us!
