Help with CMD.exe
anthonyystwarty
Help with CMD.exe
Post by anthonyystwarty »
How do I run a program that is made in DOS? It seems simple, but I can't open it through robotask. Could you help me? I created a .bat to run it through RT, but I don't think it needs it:
Ex:
@echo off
cd "C:\Test\"
start test.exe
Re: Help with CMD.exe
The command line to run some command through CMD.EXE is
cmd.exe /c <some_comand_line>
To run the program without CMD you can use Run Program/Open Document action
look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
Then you can see it in task editor
ExternalName=STRING|"Task1478"
ID=INTEGER|1106430170
Name=STRING|"run the application"
StepPause=INTEGER|0
Name=STRING|"Run ""test.exe """
ifnonzero=STRING|"0"
program=STRING|"c:\test\test.exe"
runas=STRING|"0"
wait=STRING|"0"
workdir=STRING|"c:\test"
