how to mathmatically increment a variable by another variable
rebasnop
Post by rebasnop »
how to increase a variable mathematically by adding another variable "{Line(3)}","{vPPAIQTotal}")}
trying to raise a variable by a certain percentage
doing a job using a collection of variables
Extracting a field from a text file that is separated by commas will provide the final total instead of adding up all the $'s on each line.
Re: how to mathmatically increment a variable by another variable
To add two values use Add system variable
for example
{Add({Line(3)},{vPPAIQTotal})}
Find arithmetics functions in Arithmetic operations group
For more complex calculations use VB evaluate or JS Evaluate
Vennpaul
Post by Vennpaul »
I had the same problem; but after reading this post, I understood and fixed it.
Thanks
