Error occured: Socket Error # 11001
jonjon
Post by jonjon »
I get this error when i try to ping a host. I tried to use IP and FQDN and get same error with both. If i do a manual ping it works fine. anny suggestions?
Error occured: Socket Error # 11001<CR><LF>Host not found.
Best regards
Johan
Can you tell, what command line do you use?
And, what parameters do you write into "Ping host" action?
jonjon
Post by jonjon »
Hi
sorry id ont understand what do you mean with command line?
I use www.sunet.se as aderess t ping and i use {piiing} as parameter.
is tyhat what you mean?
BR
johan
I mean: how do you did a "manual ping"?
I've just tried to "Ping host" action for www.sunet.se as address. It's working fine.
Can you send me your task?
jonjon
Post by jonjon »
It workds fine here now. I dont know whats wwrong. but i just remade the task and now it works
thanks for help!
J
Maybe, there were some network problems.
