Little bug with delete file command
mikronos
Post by mikronos »
Hi,I found a little bug wen invoke the delete file command.After giving the file name to delete and clicking on the OK button, a confirmation box with yes/no button appear.The box say "Are you sure ?" The yes/no button are inverted ( in fact because I'm french user I see a OUI / NON box. The default value is NON. But NON valid the box and YES cancel the box )-Mikronos.
Yes we know about this annoying bug. It is already fixed and will be implemented in new release.
