monitoring file
I m Possible We
monitoring file
Post by I m Possible We »
Hello, I'm trying the features of robotask... can't get it to do a simple one... yes I'm a newbee!
When a file is created  into a specific folder, I would like this file to be activated (open with it's default app.) Note: the file are downloaded from my server and I don't know their name;
I went true most of the help-me doc and still...
Thanks
monitoring file
You can run your task by "File monitor" triggering event. Also file monitor can save the list of new files into text file. Next, you can process the list in "Text loop".
Next way: You can determine the name of file within "File Loop" action.
