Remove Folder Action
OldGeek
Post by OldGeek »
My suggestion would be to add "Delete to Recycle Bin" the same as the action 'Delete File"
And why not change the action name to "Delete Folder" also to match the action "Delete File". I understand this would more than likely mess up people scripts so I'm not sure this would happen.
Thanks for a truly great product
Lana_K
Re: Remove Folder Action
Post by Lana_K »
But we already have the option to delete to recycle bin
And we have "Remove Folder" action.
Or do you mean something different?
OldGeek
Post by OldGeek »
This is what I mean. An option to send it to the Recycle Bin
