Merge multiple files into one
IT.Admin
Post by IT.Admin »
How can I use the "Copy/Move File" action to merge multiple files into one? It creates individual files rather than appending them into one file.
Re: Merge multiple files into one
You can use system command COPY
The command line for RoboTask
cmd.exe /c copy file1 + file2 + ... + fileN ResultFile
The command COPY is internal command of CMD.EXE. So you need to run CMD.EXE
For more options of COPY command use command line
copy /?
IT.Admin
Post by IT.Admin »
Thanks for your suggestion.
