PlugIn Creation
OldGeek
PlugIn Creation
Post by OldGeek »
Is it possible to make our own PlugIn? If so is there any documentation on how to do it
Re: PlugIn Creation
We didn't set out to bring in third-party developers. Therefore, we do not document the API of plugins.
The best way to add your own functionality to RoboTask is to write your own command-line console application (without GUI). The application should accept a certain set of parameters and return the desired result via StdOut (on the screen).
Then you can run this application using "Run Console Application" action and analyze the result of the application.
Believe me, this is the easiest and very effective way.
jadedpowered
Re: PlugIn Creation
Post by jadedpowered »
Can you elaborate on the specific parameters that your command-line console application should accept to integrate seamlessly with RoboTask?
Re: PlugIn Creation
You as a app developer define the required set of parameters yourself.
