String PlugIn addition
OldGeek
Post by OldGeek »
I would like to add the following function:
Space(x): Space is used to return a string containing the required number of spaces as specified inside the parenthesis.
The syntax would be: Space(number of spaces)
Re: String PlugIn addition
You can use Space function from VB script language (see VB Evaluate action)
Look at my example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
CatID=INTEGER|327819672
ExternalName=STRING|"Task1527"
ID=INTEGER|796618866
Name=STRING|"Space function"
StepPause=INTEGER|0
Name=STRING|"Set variable ""num"" with value ""20"""
_rt_variables_produced=STRING|"num"
varname=STRING|"num"
varvalue=STRING|"20"
Name=STRING|"VB Evaluate"
_rt_variables_produced=STRING|"space"
expression=STRING|"space({num})"
linecount=STRING|"0"
loadfromfile=STRING|"1"
variable=STRING|"space"
Name=STRING|"Show ""{num} spaces between quotation marks:"""
msg0=STRING|"{num} spaces between quotation marks:"
msg1=STRING|"""{space}"""
msgcount=STRING|"2"
OldGeek
Post by OldGeek »
Thank You
