runtime
photoevents
runtime
Post by photoevents »
Can you start a task using runtime (which can be found in the robotask folder under programs) if robotask was previously installed?
In such a situation, where robotask has been installed previously, do you need to uninstall robotask first before installing the runtime engine?
The question has to do with the fact that I use several laptops and sometimes want to use the robotask full install to inspect a task when on location.
Is it do-able to simply enter licence key when using laptop 1 and when swithing to another one re-entering license?
I have more than one license key, does your system keeps track?
Is it possible to lock one key to the main computer where I do the most work and have the other license key dynamic?
If my question is unclear I'll try my best to better explain after reading your feedback.
Christian
Re: runtime
You can install Runtime module to any computer without license.
Read more about runtime module here: https://robotask.com/help/index.html?runtime-module.htm
To install Runtime module only with engine use command line of installer
RobotaskSetup.exe /COMPONENTS=engine
photoevents
Re: runtime
Hey Oleg,
I know that :-)
But I want to be able to finetune some of my tasks during eventdays.
Why?
Well, because, sometimes, a task fails for reasons I did not anticipate, and I want to be able to quickly check and correct stuff.
My questions are:
Can I transfer the licenses to the laptops I'm using at any given time?
And transfer them back to my main machine.
Example:
I encounter a problem while working offsite.
I enter the license code and can correct whatever is going wrong.
For the rest of that day i run the task from the main robotask application.
When back in my office I transfer the license back to my main machine.
Next time I use runtime engine on my laptop on location.
I guess running robotask main app and having runtime installed is no problem?
Christian
Re: runtime
No.
No problem. You can use runtime version anywhere.
But runtime version can only run the task from command line: no editor, no triggers. no other tasks
