An option to load the old Robotask skin
DraBS
Post by DraBS »
Can we have an option in Settings to use the old Robotasks skin instead of the new one?
I quite much dislike the new one, find it annoying and confusing. The old one was just great, good contrast, good colour clues, clear and useful.
Re: An option to load the old Robotask skin
Old skin engine does not support Hi-res monitors. So we were forced to abandon it.
Now we are using standard Windows theme
DraBS
Post by DraBS »
Well, it'd be great to recode the old skin to be available in the new engine or have choice of similar skins, at least. The current one might be faddy, but faddy does not equal usable :(
Lana_K
Post by Lana_K »
It took me some time to get used to new icons. And although I don't have problem with new icons, I must say that it was much easier to locate a particular action in a long task or in the actions menu when icons were colourful. Maybe, if it is not possible to go back to old pics, it is feasible to add more colour to the new ones?
