simple LOOP
photoevents
simple LOOP
Post by photoevents »
I have a variable nr_prints with value 1
How can I set that variable to an integer value?
Because, simple LOOP complains about my value not being an integer.
photoevents
Re: simple LOOP
I found that when using the dialog 'Input Box' the value is not recognized as an integer.
But when using 'custom dialog' and specifying 'numbers only' the value is recognized or can be used as an integer in simple loop.
Christian
Re: simple LOOP
photoevents wrote: Tue Jun 18, 2024 12:23 pm I have a variable nr_prints with value 1
it works. Take a look at the task below.
probably you doing something wrong
CatID=INTEGER|1298793676
ExternalName=STRING|"Task323"
ID=INTEGER|-1594788966
Name=STRING|"simple loop with variables"
StepPause=INTEGER|0
Name=STRING|"Set variable ""a"" with value ""5"""
_rt_variables_produced=STRING|"a"
varname=STRING|"a"
varvalue=STRING|"5"
Name=STRING|"Set variable ""b"" with value ""10"""
_rt_variables_produced=STRING|"b"
varname=STRING|"b"
varvalue=STRING|"10"
Name=STRING|"Simple Loop"
_rt_variables_produced=STRING|"num"
begin=STRING|"{a}"
end=STRING|"{b}"
step=STRING|"1"
variable=STRING|"num"
message=STRING|"{num}"
photoevents
Re: simple LOOP
The difference is that I don't use a variable for the start value. Just typing in 1
Using custom dialog this does not matter, it seems.
Re: simple LOOP
send you task, please. Probably I don't understand you.
photoevents
Re: simple LOOP
This is the one that works, but using input box, it doesn't
CatID=INTEGER|345416516
ExternalName=STRING|"Task12"
ID=INTEGER|991448307
Name=STRING|"simpleloop"
StepPause=INTEGER|0
case#1=STRING|"0"
count=STRING|"2"
operator#1=STRING|"0"
type#1=STRING|"3"
value1=STRING|"{merge_qrcode}"
value1#1=STRING|"{print_hotfolder}"
Name=STRING|"//Ask how many prints are needed."
comment=STRING|"Ask how many prints are needed."
ActionID=STRING|"A_CUSTOM_INPUT_DIALOG"
Name=STRING|"Custom Input Dialog"
_rt_variables_produced=STRING|"DialogResult"
dialog_caption=STRING|"How many prints are required?"
dialog_height=STRING|"200"
dialog_width=STRING|"400"
field_count=STRING|"1"
field0=STRING|"{""type"":""CustomInputDialog"",""version"":""1.0"",""fieldGroups"":[{""caption"":""Field Properties"",""showCaption"":false,""fields"":[{""type"":""Simple Edit"",""labelText"":""Field Name:"",""name"":""name"",""value"":""QTY_Prints""},{""type"":""Simple Edit"",""labelText"":""Caption:"",""name"":""labelText"",""value"":""Number of Prints needed: ""},{""type"":""Simple Edit"",""labelText"":""Default Value:"",""name"":""value"",""value"":""1""},{""type"":""Checkbox"",""labelText"":""Password Input"",""name"":""passwordInput"",""value"":false},{""type"":""Checkbox"",""labelText"":""Numbers only"",""name"":""numbersOnly"",""value"":true},{""type"":""Checkbox"",""labelText"":""Required"",""name"":""required"",""value"":false}]}],""className"":""Text Edit"",""fieldName"":""QTY_Prints""}"
grid_lines=STRING|"0"
label_column_width=STRING|"140"
save_to=STRING|"DialogResult"
stop_if_cancel=STRING|"1"
vertical_layout=STRING|"0"
begin=STRING|"1"
end=STRING|"{json:DialogResult.QTY_Prints}"
step=STRING|"1"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
checkfile=STRING|"0"
destdir=STRING|"C:\DNP\Hot Folder\Prints\{DNP_hotfolder}"
f_count=STRING|"1"
file0=STRING|"{local_workfolder}\merged_qrcode\{filename}"
hidden=STRING|"0"
ifexists=STRING|"1"
maxtimeout=STRING|"15"
move=STRING|"0"
output=STRING|"0"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"0"
photoevents
Re: simple LOOP
Conclusion:
If i follow your example using var "a" as start and var "b" as end value, it works.
If I type in a value by hand in the start box, it doesn't.
Christian
Re: simple LOOP
it works without problem...
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1523"
ID=INTEGER|-844986379
Name=STRING|"Custom Input Dialog..."
StepPause=INTEGER|0
begin=STRING|"1"
step=STRING|"1"
ActionID=STRING|"A_LOG_DIALOG"
Name=STRING|"Log Dialog"
line00000000=STRING|"{num}"
photoevents
Re: simple LOOP
Okay, thanks.
Christian
