functions
photoevents
functions
Post by photoevents »
I would suggest adding a "run function" that can return a value at the end
and also within the tab actions, subtabs on the right action list that shows the functions.
that would make it easier to navigate and provide a better overview.
Christian
Re: functions
Just use VB Evaluate or JS Evaluate to calculate some values
You can use predefined language functions or write your own algorithm. Documentation has simple examples
