disable log comment ?
mikronos
Post by mikronos »
Hello,Is it possible to disable log comment ( the log line that is generated at each script line ) ? ... But with the possibility to see user comment.( comment added in a script with "CommenForm")The idea is to separate clearly user comment and system log.If it's not possible, and if others find it useful this may be an enhancement for future version. Maybe a new system variable can to that, with a true/false value to allow or not system log.( user comment can be unchecked )Huumm, but is it a global variable for all task or is it better to allow comment on/off for each task ?@+ Mikronos.
This is already implemented in new release of RoboTask. Coming very soon.
mikronos
Post by mikronos »
What can I say ?Thanks a lot!@+Mikronos.
