Help..Scheduling every 15 days and 2 Sundays per month.
anthonyystwarty
Post by anthonyystwarty »
Hello Oleg. Could you help me create a task to be performed every 15 days? And another task, every 2 Sundays a month? Thank you very much.
Re: Help..Scheduling every 15 days and 2 Sundays per month.
Look at the settings of scheduler trigger for every 15 days. You can start the task 1 and 16 days of each month
The settings of scheduler trigger for every 20nd Sunday of each month
Look at the example task wiyh the same settings (see scheduler triggers)
CatID=INTEGER|1981091247
ExternalName=STRING|"Task1494"
ID=INTEGER|-426662706
Name=STRING|"Example scheduler"
StepPause=INTEGER|0
Name=STRING|"//do sommething"
comment=STRING|"do sommething"
Event2=FOLDER
Name=STRING|"Scheduler(16.04.2024 12:00:00) //every 15 days"
UniqueID=INTEGER|-1177679853
periodicity=STRING|"2"
periodparameter=STRING|"10000000000000010000000000000000"
periodparameter2=STRING|"111111111111"
startdate=STRING|"45398"
time0=STRING|"43200000"
timecount=STRING|"1"
wakeup=STRING|"0"
[Events\Event2]
Name=STRING|"Scheduler(12.05.2024 12:00:00) //2-nd sunday"
UniqueID=INTEGER|589172534
[Events\Event2\Params]
periodicity=STRING|"1"
periodparameter=STRING|"1000000"
periodparameter2=STRING|"01000"
wakeup=STRING|"0"
anthonyystwarty
Hello Oleg, sorry for the delay in responding, I was testing the task and it worked perfectly, you and your program are the best. Thanks again for the response.
