Access is denied, ProgID: "RoboTask.App"
Chris12252
Post by Chris12252 »
I try to change th domaine of Robotask server and now I have :
Failed execute 'ExecAction with exception: Access is denied, ProgID: "RoboTask.App"' (C:\Program Files\RoboTask\Plugins\ScriptTools\ScriptTools.rtp)
User who run Robotask have admin right.
Any Idea ?
Issue with the registration code ? Is there domain server name ?
Thanks for your help
Chris12252
Re: Access is denied, ProgID: "RoboTask.App"
Ok I think it's an issue with the useris running Robotask's Service and some option Automation / Interaction service detection.
I make a back to previous domain, and it works (after lot of try).
I retry to change domain in a few days
Maybe you need to re-register COM-object of RoboTask.
The command line are:
to register COM object
robotask.exe /REGSERVER
To remove COM object from system
robotask.exe /UNREGSERVER
But please note that these command lines require administrative privileges
Or you can simply reinstall RoboTask. The installation program will perform the necessary registrations.
