If file exist
mspitzh
If file exist
Post by mspitzh »
maybe I am blind or stupid, but I don't find the function:
If file exist
/Matthias
Re: If file exist
Look at my example below.
Then you can see it in task editor
ExternalName=STRING|"Task1465"
ID=INTEGER|1102468931
Name=STRING|"If file exists"
StepPause=INTEGER|0
Name=STRING|"Set variable ""FileName"" with value ""C:\temp\test123.txt"""
_rt_variables_produced=STRING|"FileName"
varname=STRING|"FileName"
varvalue=STRING|"C:\temp\test123.txt"
value1=STRING|"{FileExists({FileName})}"
Name=STRING|"Show ""File ""{FileName}"" exists."""
msg0=STRING|"File ""{FileName}"" exists."
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""File ""{FileName}"" does not exist."""
icon=STRING|"3"
msg0=STRING|"File ""{FileName}"" does not exist."
Lana_K
Re: If file exist
Post by Lana_K »
I use If Then flow with system variable {FileExists({TempDir}\file.tmp)} which is either true or false. But for me, oddly, the variable sometimes has correct value, sometimes does not.
Re: If file exist
The variable checks for the file existence at the moment this variable is called. But the file may appear somewhat later (for example, after 0.5 seconds).
So when you look at a folder in Windows Explorer, you see the file, but the variable returns FALSE
If your file should appear and you want to wait, I recommend using the Wait for file action and waiting a while. The action can also return TRUE or FALSE.
Re: If file exist
I also recommend that you check the file for availability. Because file can be unavailable because it opened in another application.
For example, the file still being written. The file exists, but unavailable right now.
Look at the variable {IsFileFree(<Full_File_Name>)} or the action Wait for file with "Wait for accessibility of the file" option
Lana_K
Re: If file exist
Post by Lana_K »
This is a good point, thank you, Oleg.
Another issue I ran into when checking if file exists is a set of special characters (I suspect they are something to do with BOM, but I am no expert) which is added at the beginning of some files created by Robotask in UTF-8 format file names. They are invisible to naked eye and I only figured this out when pasted various filenames into text to ASCII convertor. The cure I found is to switch from UTF-8 encoding to ANSI. This solved the problem.
