Unable to export a registry key
villanrl
Post by villanrl »
Hello.
Has anyone tried using the registry export feature?  in the task below, I'm trying to export the internet explorer domain list but the file doesn't show and no errors are shown.
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|56529669
ExternalName=STRING|"Task58"
ID=INTEGER|1401692005
Name=STRING|"Export Internet Domains"
ActionID=STRING|"A_REG_EXPORT"
Name=STRING|"Export"
FileName=STRING|"C:\Documents and Settings\villanrl\Desktop\ZoneMap"
Format=STRING|"0"
KeyName=STRING|"HKEY_CURRENT_USER\Software\Microsoft\Windows \CurrentVersion\Internet Settings\ZoneMap\Domains"
Thank you for the report. This is known bug. Try to use key name with quotes, like this:
"HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion \Internet Settings\ZoneMap\Domains"
We prepare new release now and we already have fixed this.
