Sending ENTER with send keys does not work anymore
abackhaus
Post by abackhaus »
Hi
I do have a task that selects a specific window, gets the focus on that window and then I use send keystrokes to fill text followed by the ENTER-key into that window.
In the send keystroke action window I entered the text that I want to fill in, followed by {ENTER} (inserted with the little button in the GUI).
The whole task runs without any complains but the ENTER-key is not sent. The receiving window just stands with the filled in text. Usually it should close with sending ENTER-key.
I had this working without any problems and changes to my action sequence somewhen before and I do not have any idea why it is not working anymore.
Maybe you can point me into the right direction ?
Thanks and regards Albrecht
Re: Sending ENTER with send keys does not work anymore
Just try to split that function to eliminate. Like this, it helps with diagnosing where the problem really resides.
abackhaus
Post by abackhaus »
I tried that.
The result is the same. The text is filled in and {ENTER} is not sent.
Can you post your task here?
