I've created a Mouse Record (using Smart Mode), which simply repeats a series on on screen clicks and scrolls against a defined web address in chrome. It does exactly what I need once, but I want it to do what I need (repeat) for a set number of times, as a variable value (i.e. I will tell it to repeat the process 100 times), and then it should stop.
I am unsure how to add the commands to create this repeat loop... or if there is a specific function I can use to get it to repeat?
Can anyone assist please?
Thanks very much
