Robotask stuck
gremlin
Robotask stuck
Post by gremlin »
Hello, I have the problem that robotask simply stops at step 10 or 11. The task shows Active and will not continue until Robotask is ended via the task manager. After that everything goes back to normal. But after a few hours (mostly at night) it gets stuck again and only responds again after a restart.
I have the task attached
It's a very simple task. Do you have a solution for this?
Best regards
Steve
CatID=INTEGER|976360944
ContinueOnError=INTEGER|1
ExternalName=STRING|"Task21"
ID=INTEGER|1749369426
Name=STRING|"Copy of FTP - Bestandsdaten von Gautzsch herunterladen"
StepPause=INTEGER|0
Action14=FOLDER
Name=STRING|"Create File List (variable: CSVVORHANDEN)"
_rt_variables_produced=STRING|"CSVVORHANDEN"
After=STRING|"0"
aftercount=STRING|"0"
AfterLine=STRING|"0"
Before=STRING|"0"
beforecount=STRING|"0"
BeforeLine=STRING|"0"
date1=STRING|"20240206"
date2=STRING|"20240206"
destvar=STRING|"CSVVORHANDEN"
DuringMinutes=STRING|"1"
file0=STRING|"C:\JTL-TMP\Gautzsch\FTP_IN\*.csv"
savetofile=STRING|"0"
savetovar=STRING|"1"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
Name=STRING|"Prüfen ob eine Bestandsdatei heruntergeladen wurde"
_rt_variables_produced=STRING|"dateiheruntergeladen"
After=STRING|"0"
Before=STRING|"0"
date1=STRING|"20240129"
date2=STRING|"20240129"
destvar=STRING|"dateiheruntergeladen"
file0=STRING|"c:\JTL-TMP\Gautzsch\FTP_IN\*.csv"
sort=STRING|"0"
sortby=STRING|"0"
subdirs=STRING|"0"
operator=STRING|"8"
value1=STRING|"{dateiheruntergeladen}"
Name=STRING|"Start Task ""Artikelstammdaten CSV einlesen"""
[Actions\Action12\Params]
abort=STRING|"0"
parametercount=STRING|"0"
required=STRING|"0"
saveresult=STRING|"0"
taskid=STRING|"1537574101"
wait=STRING|"0"
[Actions\Action14]
Name=STRING|"Wenn keine Datei mehr da ist neue herunterladen"
connection=STRING|"1"
operator=STRING|"7"
value1=STRING|"{CSVVORHANDEN}"
value2=STRING|"4"
ActionID=STRING|"A_SFTP_LOGON"
Name=STRING|"SFTP Verbinden"
host=STRING|"xxxxx"
output=STRING|"0"
password=STRING|"8504685161851618516185161"
port=STRING|"22"
usecertificate=STRING|"0"
username=STRING|"xxxx"
ActionID=STRING|"A_SFTP_DIR"
Name=STRING|"Loop CSV Dateien"
_rt_variables_produced=STRING|"FTPCSV"
date1=STRING|"18991230"
date2=STRING|"18991230"
filenameonly=STRING|"1"
folder=STRING|"/ARTIKEL/*.*"
kind=STRING|"0"
sizesave=STRING|"0"
sort=STRING|"1"
sortby=STRING|"1"
subfolders=STRING|"0"
timesave=STRING|"0"
varname=STRING|"FTPCSV"
ActionID=STRING|"A_SFTP_GET"
Name=STRING|"Datei(en) herunterladen (von alt nach neu)"
file=STRING|"/ARTIKEL/{FTPCSV}"
folder=STRING|"c:\JTL-TMP\Gautzsch\FTP_IN\"
ifexists=STRING|"1"
recursive=STRING|"0"
Name=STRING|"Datei lokal umbennen"
file0=STRING|"c:\JTL-TMP\Gautzsch\FTP_IN\{FTPCSV}"
ifexists=STRING|"1"
mask=STRING|"Gautzsch.csv"
subdirs=STRING|"0"
ActionID=STRING|"A_SFTP_DEL"
Name=STRING|"SFTP Datei vom Server löschen"
Name=STRING|"Loop End"
ActionID=STRING|"A_SFTP_LOGOFF"
Name=STRING|"SFTP Trennen"
Name=STRING|"Scheduler(29.01.2024 17:00:00)"
UniqueID=INTEGER|-733358138
periodicity=STRING|"0"
startdate=STRING|"45320"
time0=STRING|"0"
time1=STRING|"300000"
time10=STRING|"3000000"
time100=STRING|"30000000"
time101=STRING|"30300000"
time102=STRING|"30600000"
time103=STRING|"30900000"
time104=STRING|"31200000"
time105=STRING|"31500000"
time106=STRING|"31800000"
time107=STRING|"32100000"
time108=STRING|"32400000"
time109=STRING|"32700000"
time11=STRING|"3300000"
time110=STRING|"33000000"
time111=STRING|"33300000"
time112=STRING|"33600000"
time113=STRING|"33900000"
time114=STRING|"34200000"
time115=STRING|"34500000"
time116=STRING|"34800000"
time117=STRING|"35100000"
time118=STRING|"35400000"
time119=STRING|"35700000"
time12=STRING|"3600000"
time120=STRING|"36000000"
time121=STRING|"36300000"
time122=STRING|"36600000"
time123=STRING|"36900000"
time124=STRING|"37200000"
time125=STRING|"37500000"
time126=STRING|"37800000"
time127=STRING|"38100000"
time128=STRING|"38400000"
time129=STRING|"38700000"
time13=STRING|"3900000"
time130=STRING|"39000000"
time131=STRING|"39300000"
time132=STRING|"39600000"
time133=STRING|"39900000"
time134=STRING|"40200000"
time135=STRING|"40500000"
time136=STRING|"40800000"
time137=STRING|"41100000"
time138=STRING|"41400000"
time139=STRING|"41700000"
time14=STRING|"4200000"
time140=STRING|"42000000"
time141=STRING|"42300000"
time142=STRING|"42600000"
time143=STRING|"42900000"
time144=STRING|"43200000"
time145=STRING|"43500000"
time146=STRING|"43800000"
time147=STRING|"44100000"
time148=STRING|"44400000"
time149=STRING|"44700000"
time15=STRING|"4500000"
time150=STRING|"45000000"
time151=STRING|"45300000"
time152=STRING|"45600000"
time153=STRING|"45900000"
time154=STRING|"46200000"
time155=STRING|"46500000"
time156=STRING|"46800000"
time157=STRING|"47100000"
time158=STRING|"47400000"
time159=STRING|"47700000"
time16=STRING|"4800000"
time160=STRING|"48000000"
time161=STRING|"48300000"
time162=STRING|"48600000"
time163=STRING|"48900000"
time164=STRING|"49200000"
time165=STRING|"49500000"
time166=STRING|"49800000"
time167=STRING|"50100000"
time168=STRING|"50400000"
time169=STRING|"50700000"
time17=STRING|"5100000"
time170=STRING|"51000000"
time171=STRING|"51300000"
time172=STRING|"51600000"
time173=STRING|"51900000"
time174=STRING|"52200000"
time175=STRING|"52500000"
time176=STRING|"52800000"
time177=STRING|"53100000"
time178=STRING|"53400000"
time179=STRING|"53700000"
time18=STRING|"5400000"
time180=STRING|"54000000"
time181=STRING|"54300000"
time182=STRING|"54600000"
time183=STRING|"54900000"
time184=STRING|"55200000"
time185=STRING|"55500000"
time186=STRING|"55800000"
time187=STRING|"56100000"
time188=STRING|"56400000"
time189=STRING|"56700000"
time19=STRING|"5700000"
time190=STRING|"57000000"
time191=STRING|"57300000"
time192=STRING|"57600000"
time193=STRING|"57900000"
time194=STRING|"58200000"
time195=STRING|"58500000"
time196=STRING|"58800000"
time197=STRING|"59100000"
time198=STRING|"59400000"
time199=STRING|"59700000"
time2=STRING|"600000"
time20=STRING|"6000000"
time200=STRING|"60000000"
time201=STRING|"60300000"
time202=STRING|"60600000"
time203=STRING|"60900000"
time204=STRING|"61200000"
time205=STRING|"61500000"
time206=STRING|"61800000"
time207=STRING|"62100000"
time208=STRING|"62400000"
time209=STRING|"62700000"
time21=STRING|"6300000"
time210=STRING|"63000000"
time211=STRING|"63300000"
time212=STRING|"63600000"
time213=STRING|"63900000"
time214=STRING|"64200000"
time215=STRING|"64500000"
time216=STRING|"64800000"
time217=STRING|"65100000"
time218=STRING|"65400000"
time219=STRING|"65700000"
time22=STRING|"6600000"
time220=STRING|"66000000"
time221=STRING|"66300000"
time222=STRING|"66600000"
time223=STRING|"66900000"
time224=STRING|"67200000"
time225=STRING|"67500000"
time226=STRING|"67800000"
time227=STRING|"68100000"
time228=STRING|"68400000"
time229=STRING|"68700000"
time23=STRING|"6900000"
time230=STRING|"69000000"
time231=STRING|"69300000"
time232=STRING|"69600000"
time233=STRING|"69900000"
time234=STRING|"70200000"
time235=STRING|"70500000"
time236=STRING|"70800000"
time237=STRING|"71100000"
time238=STRING|"71400000"
time239=STRING|"71700000"
time24=STRING|"7200000"
time240=STRING|"72000000"
time241=STRING|"72300000"
time242=STRING|"72600000"
time243=STRING|"72900000"
time244=STRING|"73200000"
time245=STRING|"73500000"
time246=STRING|"73800000"
time247=STRING|"74100000"
time248=STRING|"74400000"
time249=STRING|"74700000"
time25=STRING|"7500000"
time250=STRING|"75000000"
time251=STRING|"75300000"
time252=STRING|"75600000"
time253=STRING|"75900000"
time254=STRING|"76200000"
time255=STRING|"76500000"
time256=STRING|"76800000"
time257=STRING|"77100000"
time258=STRING|"77400000"
time259=STRING|"77700000"
time26=STRING|"7800000"
time260=STRING|"78000000"
time261=STRING|"78300000"
time262=STRING|"78600000"
time263=STRING|"78900000"
time264=STRING|"79200000"
time265=STRING|"79500000"
time266=STRING|"79800000"
time267=STRING|"80100000"
time268=STRING|"80400000"
time269=STRING|"80700000"
time27=STRING|"8100000"
time270=STRING|"81000000"
time271=STRING|"81300000"
time272=STRING|"81600000"
time273=STRING|"81900000"
time274=STRING|"82200000"
time275=STRING|"82500000"
time276=STRING|"82800000"
time277=STRING|"83100000"
time278=STRING|"83400000"
time279=STRING|"83700000"
time28=STRING|"8400000"
time280=STRING|"84000000"
time281=STRING|"84300000"
time282=STRING|"84600000"
time283=STRING|"84900000"
time284=STRING|"85200000"
time285=STRING|"85500000"
time286=STRING|"85800000"
time287=STRING|"86100000"
time29=STRING|"8700000"
time3=STRING|"900000"
time30=STRING|"9000000"
time31=STRING|"9300000"
time32=STRING|"9600000"
time33=STRING|"9900000"
time34=STRING|"10200000"
time35=STRING|"10500000"
time36=STRING|"10800000"
time37=STRING|"11100000"
time38=STRING|"11400000"
time39=STRING|"11700000"
time4=STRING|"1200000"
time40=STRING|"12000000"
time41=STRING|"12300000"
time42=STRING|"12600000"
time43=STRING|"12900000"
time44=STRING|"13200000"
time45=STRING|"13500000"
time46=STRING|"13800000"
time47=STRING|"14100000"
time48=STRING|"14400000"
time49=STRING|"14700000"
time5=STRING|"1500000"
time50=STRING|"15000000"
time51=STRING|"15300000"
time52=STRING|"15600000"
time53=STRING|"15900000"
time54=STRING|"16200000"
time55=STRING|"16500000"
time56=STRING|"16800000"
time57=STRING|"17100000"
time58=STRING|"17400000"
time59=STRING|"17700000"
time6=STRING|"1800000"
time60=STRING|"18000000"
time61=STRING|"18300000"
time62=STRING|"18600000"
time63=STRING|"18900000"
time64=STRING|"19200000"
time65=STRING|"19500000"
time66=STRING|"19800000"
time67=STRING|"20100000"
time68=STRING|"20400000"
time69=STRING|"20700000"
time7=STRING|"2100000"
time70=STRING|"21000000"
time71=STRING|"21300000"
time72=STRING|"21600000"
time73=STRING|"21900000"
time74=STRING|"22200000"
time75=STRING|"22500000"
time76=STRING|"22800000"
time77=STRING|"23100000"
time78=STRING|"23400000"
time79=STRING|"23700000"
time8=STRING|"2400000"
time80=STRING|"24000000"
time81=STRING|"24300000"
time82=STRING|"24600000"
time83=STRING|"24900000"
time84=STRING|"25200000"
time85=STRING|"25500000"
time86=STRING|"25800000"
time87=STRING|"26100000"
time88=STRING|"26400000"
time89=STRING|"26700000"
time9=STRING|"2700000"
time90=STRING|"27000000"
time91=STRING|"27300000"
time92=STRING|"27600000"
time93=STRING|"27900000"
time94=STRING|"28200000"
time95=STRING|"28500000"
time96=STRING|"28800000"
time97=STRING|"29100000"
time98=STRING|"29400000"
time99=STRING|"29700000"
timecount=STRING|"288"
wakeup=STRING|"0"
Re: Robotask stuck
Step #10 "Search for files"
Step #11 "if..then" action
Is this correct?
What RoboTask edition do you use: x86 or x64?
Send the system info: menu Help -> system information
How many CSV files in your folder?
gremlin
Re: Robotask stuck
Post by gremlin »
Hy,
yes, step 10 and 11 are correct.
I use Robotask x64.
Here are my system information:
RoboTask version 9.8.1.1135 (x64 edition)
Assembly version 9.8.1.292
Plugins
  "General" version 9.8.0.372
  "Dialogs and Notifications" version 9.8.0.272
  "Files and Folders" version 9.8.0.367
  "Zip" version 9.8.0.226
  "Internet" version 9.8.0.275
  "FTP Commands" version 9.8.0.225
  "SSL FTP Commands" version 9.8.0.199
  "SFTP (SSH FTP)" version 9.8.0.138
  "Dial-Up" version 9.8.0.187
  "Variables" version 9.8.0.227
  "Task Commands" version 9.8.0.206
  "Remote Task" version 9.8.0.39
  "Loops And Flows" version 9.8.0.243
  "Window" version 9.8.0.241
  "System Events" version 9.8.0.227
  "System Functions" version 9.8.0.216
  "RoboTask Commands" version 9.8.0.190
  "Clipboard" version 9.8.0.200
  "Mouse" version 9.8.0.202
  "Registry" version 9.8.0.187
  "Network" version 9.8.0.184
  "eMail" version 9.8.0.214
  "Strings" version 9.8.0.132
  "Embedded Chromium Browser" version 9.8.0.71
  "Regular Expressions" version 9.8.0.153
  "ScreenShot" version 9.8.0.113
  "INI files" version 9.8.0.29
  "XML Document" version 9.8.0.88
  "Script Tools" version 9.8.0.45
  "Excel" version 9.8.0.79
  "Sound Volume" version 9.8.0.60
  "DataBase" version 9.8.0.77
  "CSV Data" version 9.8.0.11
  "Graphics" version 9.8.0.40
  "WebSockets" version 9.8.0.40
  "Console Application" version 9.8.0.28
  "Converter" version 9.8.0.4
  "HDD S.M.A.R.T." version 9.8.0.3
Processor Info
Manufacturer: GenuineIntel
Type:  8664
Count: 16
Level: 6
Model: 165, Step: 5
Speed: 2904 MHz
Processor name: Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz
Memory Info
Physical memory:        16.875.368.448
Physical memory avail:  6.015.827.968
Physical memory Load:   64%
Total virtual Memory:   26.002.173.952
Avail virtual Memory:   8.343.912.448
Virtual Memory Load:    68%
RoboTask's working set: 81912 Kb
OS Info
OS version: 10.0 () x64 edition
Build: 22631
Platform: Windows NT
Monitors count 2
Monitor 0 resolution: 1920x1200 (primary)
Monitor 1 resolution: 1920x1200
Disks Info
C: Fixed
   Total 509.357.322.240 bytes; Free 185.211.486.208 bytes; Cluster size 4.096
D: Removable
System folders
Windows path: "C:\WINDOWS"
Program Files path: "C:\Program Files"
Temporary folder path: "C:\Users\STRAND~1\AppData\Local\Temp"
Re: Robotask stuck
Hm-m-m...
I afraid that your disk has some logical problem
Try to check and fix problems on disk. Command line is:
chkdsk c: /f
Since drive C is the system drive, the system will need to be rebooted. Checking the system on the disk before booting the system.
I tried these actions with large folder (~70000 files). It works in a few seconds
gremlin
Re: Robotask stuck
Post by gremlin »
I've already run checkdisk.
It's all right.
Already restarted the PC.
The task normally downloads 1 .csv file via FTP.
This is renamed and then checked to see if a file exists.
I'm surprised he hangs himself doing this.
I have other tasks that also check for files.
These have no problem and work perfectly.
Only this task causes problems, but only after several hours. e.g. This morning it not worked again, then I restarted Robotask and so far it's been running without any problems...
Re: Robotask stuck
For your information
To check file existence by mask use {FileExists(<FileName>)} variable
It returns True or False
for example
{FileExists(D:\incoming\large\*.txt)}
gremlin
Re: Robotask stuck
Post by gremlin »
You mean so ?
Re: Robotask stuck
You mean so ?
Yes
gremlin
Re: Robotask stuck
Post by gremlin »
Ok, I`ll try
gremlin
Re: Robotask stuck
Post by gremlin »
Hy,
look here. It crashed ...
