Assign True or False to Variable in Check for Window action
fbourne
Post by fbourne »
I am trying to use the Check for Window action to assign a value of False to a variable but can't figure out what to enter in the box to achieve this. I set a Local Variable to an initial value of True and want to set that variable to false when a certain pop up window appears. I have the correct window selected but the attempt to assign the variable a new value is "Invalid".
The documentation does not specify how to use this function. Can you help? Thank you
Re: Assign True or False to Variable in Check for Window action
Look at screenshot below.
Set the action options as shown on screenshot
