Pick random file
Pick random file
Hey Oleg and team!
Situation: We are using Robotask at a regional radiostation and are planning to mix the audiobed and the news together with sox, hourly executed ofcourse. That's already working great.
However, we are getting new beds with the hour in it. "The news from 5 o'clock, 6 o'clock" etc with +- 3 variants per hour. So, I have like 36 beds, more or less.
Hour03_A.wav
Hour03_B.wav
Hour03_C.wav
In the naming of the bed (File search: 3*.wav) I can narrow it down to the correct hour with a variable, but the variant should be somehow random, no specific order. How can I program Robotask the best way (in your approach) to pick a rondom Hour{Hour}_x.wav file?
Zac
Re: Pick random file
Post by Zac »
I saw the question and wanted to put a quick answer if this works for you. You can create a new variable or set a variable you already have or within your actions for calling the "random hour{Hour}_x.wav" file, you can call the system variable "{RandomValue(1000)}" and it will provide that variant I think your asking for. By default in the notes for this, it mentions it defaults to 1000 but you can change that value to be the limit you want it to be random for so it could be "{RandomValue(12)}{Hour}_x.wav" when you call the file to be used.
Good idea, thanks for the heads up. I will try this option. 8-)
Look at the example below.
CatID=INTEGER|1163085779
ExternalName=STRING|"Task1442"
ID=INTEGER|-385310292
Name=STRING|"Random file name"
StepPause=INTEGER|0
Name=STRING|"Set variable ""num"" with value ""{RandomValue(1000)}"""
_rt_variables_produced=STRING|"num"
varname=STRING|"num"
varvalue=STRING|"{RandomValue(1000)}"
Name=STRING|"If Then \\<=333"
operator=STRING|"4"
type=STRING|"1"
value1=STRING|"{num}"
value2=STRING|"333"
Name=STRING|"Set variable ""filename"" with value ""Hour{Hours}_A.wav"""
_rt_variables_produced=STRING|"filename"
varname=STRING|"filename"
varvalue=STRING|"Hour{Hours}_A.wav"
ActionID=STRING|"A_FLOW_ELSEIF"
Name=STRING|"ElseIf Then \\ <=666"
operator=STRING|"4"
value2=STRING|"666"
Name=STRING|"Set variable ""filename"" with value ""Hour{Hours}_B.wav"""
varvalue=STRING|"Hour{Hours}_B.wav"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Set variable ""filename"" with value ""Hour{Hours}_C.wav"""
varvalue=STRING|"Hour{Hours}_C.wav"
message=STRING|"{num}; {filename}"
Great purposal Oleg, I will try that as well.
