start task when user logs in
abackhaus
Post by abackhaus »
Good day
I may have missed it or I have not understand the docs properly - I am looking for the trigger to start a task when the user logs on to the computer.
Thanks for help and happy New Year.
Albrecht
Re: start task when user logs in
If you use RoboTask as simple application you can switch ON the parameter "Run task on RoboTask start"
When you open new user session system start RoboTask automatically
Also look at the trigger On Local/Remote Session Changes. You can find it in System Events group
It can respond to multiple session entry modes (or session exit).
