Photography
photoevents
Photography
Post by photoevents »
I am using scripts mainly to automate my photography workflow on events.
I use commandline imagemagick.
Robotask has some image actions but these are too simple for the rather complicated photo manipulations I need.
My question is:
Could imagemagick be added as a plugin to robotask ?
It's open source and it would add a lot of value to users like me.
On the other hand, using IM as a console app with commandline parameters has worked well for many years now.
Always looking at simplifying things (at least to me ;-) )
Christian
Re: Photography
You can use imagemagic as a command-line tool with using Run Program/Open Document and Run Console Application actions
