Email addresses with variables
deesloop
Post by deesloop »
Is it possible to use variables in email addresses??
I want to grab the first few characters (based on the position of a "-" delimiter) of a filename and assign that text to a variable sendto then send an email to {sendto}@mydomain.net
It fails every time with a bad email address but the address is valid and I'm not sure if the variable is being passed or whether it's just the actual text {sendto}@mydomain.net address that is being passed
Thanks
Re: Email addresses with variables
Yes, you can use use variables in recipient address. It works, I just tested this
You can set to variable SendTo the username and next use it in address {SendTo}@mydomain.net
This mist work if your variable does not break syntax of email address.
Try to output the expression {SendTo}@mydomain.net. Maybe it contains some prohibited symbols: linebreaks, spaces and others
deesloop
Post by deesloop »
Yes, it worked for sure. I had used {sendto}@mydomain.net and although my string manipulation was working I couldn't get it to work
I created a new task and it worked first time so can only assume I had done something daft.
Thanks for your quick response
