juanlu
Posts: 49 Joined: Wed Jul 31, 2019 12:33 am
Post
by juanlu » Thu Nov 16, 2023 9:30 am
When I try to use the Crop image action, I always get an error "Invalid values". I have tried the following values for Left, Top, Right, Bottom:
{var1}, {var2} , {var3}, {var4}
I have tried with the above values with both pixels and percentage. Always the same error.
The image is a png file. The file exists and is read successfully by RoboTask. I can get its metadata correctly. I can use the Save image action to save the same image to a different file correctly. Everything works except cropping.
Any ideas?
Kind regards, Juanlu.
juanlu
Post
by juanlu » Thu Nov 16, 2023 9:32 am
CatID=INTEGER|637835070
ExternalName=STRING|"Task29"
ID=INTEGER|-20513676
LocalVariables=STRING|"c_Crop_Pixels_Bottom=0,c_Crop_Pixels_Left=0,c_Crop_Pixels_Right=0,c_Crop_Pixels_Top=0,c_Folder_Name_Output=cropped_by_RT,c_Full_Folder_Name_Input=D:\temp\test,v_File_Name,v_Image_Width"
Name=STRING|"Crop all images in folder"
StepPause=INTEGER|0
Action14=FOLDER
Action15=FOLDER
Action16=FOLDER
value1=STRING|"{FolderExists({c_Full_Folder_Name_Input})}"
ActionID=STRING|"A_GRAPHICS_CROP_IMAGE"
Enabled=INTEGER|0
Name=STRING|"Crop image ({c_Crop_Pixels_Left}px, {c_Crop_Pixels_Top}px) - ({c_Crop_Pixels_Right}px, {c_Crop_Pixels_Bottom}px)"
b=STRING|"{c_Crop_Pixels_Bottom}"
l=STRING|"{c_Crop_Pixels_Left}"
r=STRING|"{c_Crop_Pixels_Right}"
t=STRING|"{c_Crop_Pixels_Top}"
ub=STRING|"0"
ul=STRING|"0"
ur=STRING|"0"
ut=STRING|"0"
Enabled=INTEGER|0
Name=STRING|"Crop image (0px, 0px) - (0px, 0px)"
b=STRING|"0"
l=STRING|"0"
r=STRING|"0"
t=STRING|"0"
ub=STRING|"0"
ul=STRING|"0"
ur=STRING|"0"
ut=STRING|"0"
Enabled=INTEGER|0
Name=STRING|"Crop image (0%, 0%) - (0%, 0%)"
[Actions\Action12\Params]
b=STRING|"0"
l=STRING|"0"
r=STRING|"0"
t=STRING|"0"
ub=STRING|"1"
ul=STRING|"1"
ur=STRING|"1"
ut=STRING|"1"
Enabled=INTEGER|0
Name=STRING|"Crop image (1px, 0px) - (0px, 0px)"
[Actions\Action13\Params]
b=STRING|"0"
l=STRING|"1"
r=STRING|"0"
t=STRING|"0"
ub=STRING|"0"
ul=STRING|"0"
ur=STRING|"0"
ut=STRING|"0"
[Actions\Action14]
Enabled=INTEGER|0
Name=STRING|"Crop image (-1px, 0px) - (0px, 0px)"
[Actions\Action14\Params]
b=STRING|"0"
l=STRING|"-1"
r=STRING|"0"
t=STRING|"0"
ub=STRING|"0"
ul=STRING|"0"
ur=STRING|"0"
ut=STRING|"0"
[Actions\Action15]
ActionID=STRING|"A_GRAPHICS_SAVE_IMAGE"
Name=STRING|"Save image to '{c_Full_Folder_Name_Input}\{c_Folder_Name_Output}\{v_File_Name}'"
[Actions\Action15\Params]
dest=STRING|"0"
format=STRING|"0"
if_exists=STRING|"0"
image_file=STRING|"{c_Full_Folder_Name_Input}\{c_Folder_Name_Output}\{v_File_Name}"
save_meta=STRING|"0"
[Actions\Action16]
Name=STRING|"Create Folder ({c_Full_Folder_Name_Input}\{c_Folder_Name_Output})"
newfolder=STRING|"{c_Full_Folder_Name_Input}\{c_Folder_Name_Output}"
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"v_File_Name"
date1=STRING|"20231116"
date2=STRING|"20231116"
destvar=STRING|"v_File_Name"
DuringMinutes=STRING|"1"
file0=STRING|"{c_Full_Folder_Name_Input}\*.png"
file1=STRING|"{c_Full_Folder_Name_Input}\*.jpg"
file2=STRING|"{c_Full_Folder_Name_Input}\*.jpeg"
file3=STRING|"{c_Full_Folder_Name_Input}\*.bmp"
filecount=STRING|"4"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
WithoutPath=STRING|"1"
Name=STRING|"Log Message - v_File_Name"
message=STRING|"v_File_Name: {v_File_Name}"
ActionID=STRING|"A_GRAPHICS_OPEN_IMAGE"
Name=STRING|"Open image from '{c_Full_Folder_Name_Input}\{v_File_Name}'"
image_file=STRING|"{c_Full_Folder_Name_Input}\{v_File_Name}"
source=STRING|"0"
Name=STRING|"Log Message - c_Full_Folder_Name_Input\v_File_Name"
message=STRING|"c_Full_Folder_Name_Input\v_File_Name: {c_Full_Folder_Name_Input}\{v_File_Name}"
ActionID=STRING|"A_GETMETADATA"
Name=STRING|"Get File Metadata from file {c_Full_Folder_Name_Input}\{v_File_Name}"
_rt_variables_produced=STRING|"v_Image_Width"
filename=STRING|"{c_Full_Folder_Name_Input}\{v_File_Name}"
prop00000000=STRING|"ancho"
propcount=STRING|"1"
var00000000=STRING|"v_Image_Width"
Name=STRING|"Log Message - v_Image_Width"
message=STRING|"v_Image_Width: {v_Image_Width}"
Posts: 3297 Joined: Thu Jan 01, 1970 1:00 am
Post
by Oleg » Thu Nov 16, 2023 7:16 pm
Thank you for your report.
Thanks to your message, we discovered a small bug in the action.
The problem was that the
Right and
Bottom parameters could not be equals to 0.
We have already fixed this bug and released update. Just diwnload and install fresh copy here (version 9.7.2):
https://robotask.com/download/
Test your task and tell about results.
juanlu
Post
by juanlu » Fri Nov 17, 2023 11:49 am
Hi Oleg,
Thanks for your quick response. Now it works as expected.
