Moves the mouse pointer using VARIABLES
I reccommend the possibility to specify possition where to move the mouse also using variables.
Re: Moves the mouse pointer using VARIABLES
Look at the Mouse move cursor action. You can specify absolute coordinates or relateive (from current cursor position)
You can also specify coordinates explicitly or using variables.
Great. I have tried it and it worked. I was confused that there is no option to choose the variable ....
- Attachments
- Screenshot_1.png (7.25 KiB) Viewed 42516 times
Hm-m... This is our omission...I was confused that there is no option to chose
Will be added in next release
Thanks. You replied so quick - I was not able to finish editing my post "
It works even in a text loop. It is for me very nice possibility - I can prepare (and modify) list of coordinates
