alarmclock
sen5243
alarmclock
Post by sen5243 »
hi
is there anyone who got an example task for an alarmclock for me?
the only thing i need is:
When you start the task, you get a popup window which asks what time you want to set the clock. The popup should already contain the system time and up and down arrows to change it. When you've pressed OK the task will pauze and comes in action at the time you've set
thanks richard
alarmclock
I recommend you to use "Scheduler" triggering event to make the alarm clock. Also RoboTask doesn't allow you to create arbitrary dialog window. It may be possible only with using of basic script.
See this example of alarm clock. It play sound file at 7:00 and ask you to stop alarm.
