CPU 100% Wait for application exit
confucion
Post by confucion »
When I run a MS-DOS batch file in console mode and wait for the app to
exit, Robotasks overloads the CPU to 100%. Is this normal?
Are you sure that RoboTask overloads your processor? Maybe, it is work of your application.
Can I see this .bat file?
BTW: I've just tested with such batch file
echo Hello world!
pause
RoboTask doesn't load processor at all
confucion
Post by confucion »
I tested your sample script also, you're right, it is the work of my application, not robotask itself.
