display a text in a box without any butto
sen5243
Post by sen5243 »
is it possible to display a text or string without any buttons, and always updated
thanks richard
;* RoboTask Task file *
;* Do not edit!       *
CatID=INTEGER|0
ExternalName=STRING|"Task1"
ID=INTEGER|297032381
Name=STRING|"winamp-shutdown at 30min"
Name=STRING|"Input Box"
default=STRING|"0"
prompt=STRING|"winamp shut down at 30 min"
variable=STRING|"{WINAMPTIME}"
Name=STRING|"Simple Loop"
begin=STRING|"1"
end=STRING|"{WINAMPTIME}"
variable=STRING|"TELLER"
Name=STRING|"Delay 1000 ms"
delay=STRING|"10"
Name=STRING|"Show ""{TELLER}"""
msg0=STRING|"{TELLER}"
Name=STRING|"Close window """""
action=STRING|"4"
caption=STRING|"0"
child=STRING|"0"
class=STRING|"1"
classexact=STRING|"0"
exact=STRING|"0"
findmode=STRING|"0"
hidden=STRING|"0"
processall=STRING|"0"
winclass=STRING|"Winamp v1.x"
hotkey=STRING|"24663"
"Show message/Play sound" is an interactive action which require pressing a key or mouse button. If you need simply to output some information you can use "Log message". This action output specified string into log of task.
You can see a log of task at bottom of main window when you selected corresponding task.
sen5243
Post by sen5243 »
hi oleg
thanks for the reaction
but i dont want to log anything
the only thing i want is a small visual Notification window that is alway updated
thanks richard
Hmm...
Maybe, we'll add such action in future.
sen5243
Post by sen5243 »
thanks richard
ahunkins
Post by ahunkins »
I use the question dialog.  But I don't ask a question, I put in the notice.  Then I set the auto-button-press feature for as long as I want the message to be displayed.
I guess you could put this into a loop to continually update you.
