How to delete files from multiple folders using *.
anthonyystwarty
Post by anthonyystwarty »
My greetings. It looks like an easy command, but I can't execute it. As an example I have the folder, c:\test1, c:\test2\, c:\test3...with several files in each folder, but I would just like to exclude them with the .mp3 extension...how do I do that? I thought that way...
In addition to the command below, I also tried , "...and I couldn't
Re: How to delete files from multiple folders using *.
Why? I thied this, it works without problem
Look at my example. It works as designed: removes all *.TXT files from 3 folders to "Recycle bin"
ExternalName=STRING|"Task23"
ID=INTEGER|736587820
Name=STRING|"delete files from several folders"
StepPause=INTEGER|0
Name=STRING|"Delete File"
Count=STRING|"3"
deletedirs=STRING|"0"
deletereadonly=STRING|"0"
file0=STRING|"C:\test1\*.txt"
file1=STRING|"C:\test2\*.txt"
file2=STRING|"C:\test3\*.txt"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"1"
anthonyystwarty
Hello Oleg! You are incredible. Thank you very much. Your example worked perfectly.
