CSV Data Loop with text from variable
sarnusch
Post by sarnusch »
I am just testing the new CSV features of version 9.6 and I noticed the following error.
After opening a CSV file ('CSV Open Data') and saving it to a variable ('CSV Save Data') I can not use a 'CSV Data Loop'.
The following error occurs:
Screenshot 2023-07-10 151925.png (14.4 KiB) Viewed 14416 times
After disabeling 'Skip empty lines' the loop works:
Screenshot 2023-07-10 152046.png (25.11 KiB) Viewed 14416 times
This is odd because the lines are not empty.
Content of example file (csv_test.csv):
1;2;3;4;5
6;7;8;9;10
11;12;13;14;15
Re: CSV Data Loop with text from variable
Send your task example to me, please
Aslo exact CSV file. It seem it has empty lines at the end.
But you are correct. There is some bug. We'll fix it ASAP
sarnusch
Post by sarnusch »
you can find the task and the file in the attachement of this post.
OpenCSVLoop.zip
(1016 Bytes) Downloaded 1186 times
Thank you very much for your simple example
This helped to detect and remove several bugs in the plugin.
The plugin already fixed. Download and test your examples.
>> Download fresh copy (ver 9.6.3) <<
sarnusch
Post by sarnusch »
i installed new version and tested it and the problem is solved.
Thanks!
