XML Node
XML Node
Hey Oleg,
I'm struggeling with this for a long time and I really need your help. I'm missing things, I guess. Now suffering from tunnelvision!
I have the following XML file:
<?xml version="1.0" encoding="UTF-8"?>
<NisPodcastExport>
<Id>778D7A65B950F30DC12589DA00170047<Id>
<Published>True<Published>
<Author>Name of the host</Author>
<Category>DIF1</Category>
<Headline>HeadlineTitleHere</Headline>
<Body><![CDATA[<p>Description for the website</p>
<p><strong>Automatisch?</strong></p>
<p>Wil je voortaan elke ochtend deze podcast automatisch ontvangen? Plak dan&nbsp;<a href="https://script.dummydomain.nl/feed/podcast.xml" target="_blank">deze&nbsp;link</a>
&nbsp;(https://script.dummydomain.nl/feed/podcast.xml) in je favoriete podcastprogramma of -app. Bij Apple- en Google-podcast: zoek op "dummycompany".&nbsp;&nbsp;
</p>
]]></Body>
<Keywords></Keywords>
<Publication display="true">2023-06-26T06:11:14+02:00</Publication>
<Archive></Archive>
<Picture sourceId="A83D01B3C58FFB40C1258330002D318B" published="True">
<Filename>DEFAULT_PODCAST_A83D01B3C58FFB40C1258330002D318B.jpg</Filename>
<Still>DEFAULT_PODCAST_thumb_A83D01B3C58FFB40C1258330002D318B.jpg</Still>
<Title>DJ1 en DJ2 praten je bij</Title>
<Description>DJ1 en DJ2 praten je bij</Description>
<Rights></Rights>
<internal>0</internal>
</Picture>
<Audio sourceId="8D47AD2A37C6A6E3C12589DA001BEA2E" published="True">
<Filename>1017224.mp3</Filename>
<Still>audiostill.jpg</Still>
<Rights></Rights>
</Audio>
</NisPodcastExport>
What I want is relatively simple: I want to extract the values between the nodes, in bold text. I've tried already a lot of things, but no output what so ever. What is your advise?
Re: XML Node
This is wrong XML file.
I see at least two errors
<Id>778D7A65B950F30DC12589DA00170047</Id>
<Published>True</Published>
It can not be processed as XML
Where did you get this text? If the text must have correct XML format then this is simple job
Look at my example below (I have corrected your "XML" in the task).
ExternalName=STRING|"Task1367"
ID=INTEGER|481232199
Name=STRING|"Parse XML"
StepPause=INTEGER|0
Name=STRING|"Set variable ""xmlText"" with value ""<?xml version=""1.0"" encoding=""UTF-8""?>"""
_rt_variables_produced=STRING|"xmlText"
linecount=STRING|"36"
varname=STRING|"xmlText"
varvalue=STRING|"<?xml version=""1.0"" encoding=""UTF-8""?>"
varvalue00000001=STRING|"<NisPodcastExport>"
varvalue00000002=STRING|"	<Id>778D7A65B950F30DC12589DA00170047</Id>"
varvalue00000003=STRING|"	<Published>True</Published>"
varvalue00000004=STRING|"	<Author>Name of the host</Author>"
varvalue00000005=STRING|"	<Category>DIF1</Category>"
varvalue00000006=STRING|"	<Headline>HeadlineTitleHere</Headline>"
varvalue00000007=STRING|"	<Body><![CDATA[<p>Description for the website</p>"
varvalue00000009=STRING|"<p><strong>Automatisch?</strong></p>"
varvalue0000000B=STRING|"<p>Wil je voortaan elke ochtend deze podcast automatisch ontvangen? Plak dan&nbsp;<a href=""https://script.dummydomain.nl/feed/podcast.xml"" target=""_blank"">deze&nbsp;link</a>"
varvalue0000000C=STRING|"&nbsp;(https://script.dummydomain.nl/feed/podcast.xml) in je favoriete podcastprogramma of -app. Bij Apple- en Google-podcast: zoek op ""dummycompany"".&nbsp;&nbsp;</p>"
varvalue0000000D=STRING|"]]></Body>"
varvalue0000000E=STRING|"	<Keywords/>"
varvalue0000000F=STRING|"	<Publication display=""true"">2023-06-26T06:11:14+02:00</Publication>"
varvalue00000010=STRING|"	<Archive/>"
varvalue00000011=STRING|"	<Picture sourceId=""A83D01B3C58FFB40C1258330002D318B"" published=""True"">"
varvalue00000012=STRING|"		<Filename>DEFAULT_PODCAST_A83D01B3C58FFB40C1258330002D318B.jpg</Filename>"
varvalue00000013=STRING|"		<Still>DEFAULT_PODCAST_thumb_A83D01B3C58FFB40C1258330002D318B.jpg</Still>"
varvalue00000014=STRING|"		<Title>DJ1 en DJ2 praten je bij</Title>"
varvalue00000015=STRING|"		<Description>DJ1 en DJ2 praten je bij</Description>"
varvalue00000016=STRING|"		<Keywords/>"
varvalue00000017=STRING|"		<Rights/>"
varvalue00000018=STRING|"		<internal>0</internal>"
varvalue00000019=STRING|"	</Picture>"
varvalue0000001A=STRING|"	<Audio sourceId=""8D47AD2A37C6A6E3C12589DA001BEA2E"" published=""True"">"
varvalue0000001B=STRING|"		<Filename>1017224.mp3</Filename>"
varvalue0000001C=STRING|"		<Still>audiostill.jpg</Still>"
varvalue0000001D=STRING|"		<Title>DJ1 en DJ2 praten je bij</Title>"
varvalue0000001E=STRING|"		<Description>DJ1 en DJ2 praten je bij</Description>"
varvalue0000001F=STRING|"		<Keywords/>"
varvalue00000020=STRING|"		<Rights/>"
varvalue00000021=STRING|"		<internal>0</internal>"
varvalue00000022=STRING|"	</Audio>"
varvalue00000023=STRING|"</NisPodcastExport>"
ActionID=STRING|"A_XML_GETNODE"
Name=STRING|"XML Get Single Node"
_rt_variables_produced=STRING|"author"
attcount=STRING|"0"
foundresult=STRING|"0"
foundresultvariable=STRING|"f"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"\*\Author"
raiseerror=STRING|"1"
savechildcount=STRING|"0"
savedepth=STRING|"0"
savenodename=STRING|"0"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
textvar=STRING|"author"
xml00000000=STRING|"{xmlText}"
xmlcount=STRING|"1"
_rt_variables_produced=STRING|"category"
attcount=STRING|"0"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"\*\Category"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
textvar=STRING|"category"
xmlcount=STRING|"1"
_rt_variables_produced=STRING|"headline"
attcount=STRING|"0"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"\*\Headline"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
textvar=STRING|"headline"
xmlcount=STRING|"1"
_rt_variables_produced=STRING|"body"
attcount=STRING|"0"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"\*\Body"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
textvar=STRING|"body"
xmlcount=STRING|"1"
_rt_variables_produced=STRING|"Title"
attcount=STRING|"0"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"\*\Picture\Title"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
textvar=STRING|"Title"
xmlcount=STRING|"1"
_rt_variables_produced=STRING|"Description"
attcount=STRING|"0"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"\*\Picture\Description"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
textvar=STRING|"Description"
xmlcount=STRING|"1"
_rt_variables_produced=STRING|"Filename"
attcount=STRING|"0"
loadfile=STRING|"0"
ordernum=STRING|"0"
path=STRING|"\*\Audio\Filename"
savepath=STRING|"0"
savetext=STRING|"1"
savexml=STRING|"0"
textvar=STRING|"Filename"
xmlcount=STRING|"1"
Name=STRING|"Show Text"
autoclose=STRING|"0"
fromfile=STRING|"1"
line00000000=STRING|"Author: {author}"
line00000001=STRING|"Category: {category}"
line00000002=STRING|"Headline: {headline}"
line00000003=STRING|"Title: {Title}"
line00000004=STRING|"FileName: {Filename}"
line00000006=STRING|"Body:"
line00000007=STRING|"{body}"
line00000008=STRING|"--------"
linecount=STRING|"9"
timeout=STRING|"10"
Re: XML Node
Oleg wrote: Thu Jul 06, 2023 2:45 pm This is wrong XML file.
Correct, I've noticed that after pasting as well.
Thanks for this heads-up, this really pushes me into the right direction!
