Extract E-mail address from text
sarnusch
Post by sarnusch »
I am trying to get an email address out of a string with different information but I can not get it to work.
The domain is always the same: "@example.com"
But the string before the domain is always different and also the length differs.
Before the email address is always at least one space.
Is there a smart way to find the full email address in a string?
Re: Extract E-mail address from text
Yes of course. Use regular expressions
Also look at my small example below.
CatID=INTEGER|799397369
ExternalName=STRING|"Task14"
ID=INTEGER|-753970022
Name=STRING|"Extract email address from string"
StepPause=INTEGER|0
Name=STRING|"Set variable ""SourceString"" with value ""Example of string with email address. The address is example.address@example.com. Extract it please."""
_rt_variables_produced=STRING|"SourceString"
varname=STRING|"SourceString"
varvalue=STRING|"Example of string with email address. The address is example.address@example.com. Extract it please."
Name=STRING|"RegExp Match"
_rt_variables_produced=STRING|"expression,res"
anchored=STRING|"0"
extended=STRING|"0"
line00000000=STRING|"{SourceString}"
multiline=STRING|"0"
noautocapture=STRING|"0"
pattern=STRING|"([0-9a-zA-Z_\.]+@[0-9a-zA-Z_]+?\.[a-zA-Z]+)"
savesubexpression=STRING|"1"
singleline=STRING|"0"
subexpressionpos=STRING|"0"
subexpressionvar=STRING|"expression"
ungreedy=STRING|"0"
useexternal=STRING|"0"
variable=STRING|"res"
value1=STRING|"{res}"
Name=STRING|"Show ""{SourceString}"""
msg0=STRING|"{SourceString}"
msg1=STRING|"******"
msg2=STRING|"Email is: {expression(1)}"
msgcount=STRING|"3"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""The string does not contain email address!"""
icon=STRING|"3"
msg0=STRING|"The string does not contain email address!"
sarnusch
Post by sarnusch »
that works perfectly.
Thank you very much!
