Can you iterate through every X number of files?
brianmisty
Post by brianmisty »
I would like to automate a process to iterate through every 3 files in a folder and open them in Photoshop. Photoshop will run a series of actions and then save and close the files. Photoshop actions can handle all but the importing of the 3 images. Can RoboTask do this?
Re: Can you iterate through every X number of files?
Use file loop action
Also look at my small example below.
Next you can see it in task editor
ExternalName=STRING|"Task1004"
ID=INTEGER|857991014
Name=STRING|"How to use File Loop"
StepPause=INTEGER|0
Name=STRING|"File Loop"
_rt_variables_produced=STRING|"FileName"
date1=STRING|"20230622"
date2=STRING|"20230622"
destvar=STRING|"FileName"
DuringMinutes=STRING|"1"
file0=STRING|"D:\incoming\*.txt"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
message=STRING|"Do something with file {FileName}"
