Send to previous active window
fablefox
Post by fablefox »
Previously I use a software called Fast Paste. Currently I'm testing robotask trial to see if it fit my need. however, i have a simple question.
For Fast Paste, how I use it was:
1) click on notepad ( or any other app)
2) click on fast paste. click to run any command.
Fast Paste will send keys to notepad (or any other app)
But apparently this style doesn't work with Robotask, since selecting robotask will make robotask the current app and any keystroke will be sent to itself.
How do I do this in robotask? currently i'm testing by using part of string in app name, but this will be an issue if i have multiple of the same app open. for example i have putty1, putty2 and putty3 and i want to sent keystroke to only putty3.
is there a way to send keystroke to previously selected windows?
Re: Send to previous active window
Look at my example below.
Select input field, press CTRL+SHIFT+V, select text and press Enter key
ExternalName=STRING|"Task1040"
ID=INTEGER|585691058
Name=STRING|"Insert common texts"
StepPause=INTEGER|0
Name=STRING|"Create local variable ""WIN"" with value ""{CurrentWindowHandle}"""
varname=STRING|"WIN"
varvalue=STRING|"{CurrentWindowHandle}"
ActionID=STRING|"A_DIALOG_CHOICE"
Name=STRING|"Choice Dialog"
_rt_variables_produced=STRING|"TXT"
autochoice=STRING|"0"
mode=STRING|"1"
nearcursor=STRING|"1"
result=STRING|"0"
savemode=STRING|"1"
stopifcancel=STRING|"0"
textsource=STRING|"1"
timeout=STRING|"10"
title=STRING|"Choose the text"
txtcount=STRING|"3"
txtline00000000=STRING|"Item 1"
txtline00000001=STRING|"Item 2"
txtline00000002=STRING|"Item 3"
variable=STRING|"TXT"
value1=STRING|"{TXT}"
value2=STRING|"0"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit"
Name=STRING|"Focus window by handle"
action=STRING|"0"
caption=STRING|"1"
child=STRING|"0"
class=STRING|"0"
classexact=STRING|"0"
exact=STRING|"0"
findmode=STRING|"1"
handle=STRING|"{win}"
hidden=STRING|"0"
processall=STRING|"0"
currentwindow=STRING|"1"
fixedwindow=STRING|"0"
keylayout=STRING|"0"
keys=STRING|"{TXT}"
pause=STRING|"20"
release=STRING|"1"
sendkind=STRING|"0"
wincaption=STRING|"Notepad"
Name=STRING|"Shift+Ctrl+V"
UniqueID=INTEGER|-1573046433
hotkey=STRING|"24662"
fablefox
Post by fablefox »
I think this didn't work because when run, CurrentWindowHandle gets Robotask own handle, which means it will set itself to focus and send keys to itself?
I think this didn't work because when run, CurrentWindowHandle gets Robotask own handle, ...
CurrentWindowHandle gets the handle of active window. If you activate Notepad before you press Hot-Key then it gets the handle of Notepad window.
By the way this example is the copy of my task I use to put some standard phrases into edit field.
fablefox
Post by fablefox »
Thanks, it worked by using hotkey. But this doesn't fit my workflow. I'm starting a new post to ask a new technique.
