1 file to multiple folders? How?
anthonyystwarty
Post by anthonyystwarty »
Hello, my greetings. In the copy/move action, can I copy or move multiple files from different sources to multiple folders, and vice versa? how do I do? 1 file for multiple folders? Thanks
Re: 1 file to multiple folders? How?
how do I do?
Use loops.
Look at the example below how to copy one file to multiple folders
Next you can see it (and edit it) in the the task editor
ExternalName=STRING|"Task77"
ID=INTEGER|2010785613
Name=STRING|"One file to multiple folders"
StepPause=INTEGER|0
Name=STRING|"Set variable ""FileName"" with value ""D:\incoming\test.txt """
_rt_variables_produced=STRING|"FileName"
varname=STRING|"FileName"
varvalue=STRING|"D:\incoming\test.txt "
Name=STRING|"Set variable ""Folders"" with value ""D:\dest\folder1"""
_rt_variables_produced=STRING|"Folders"
linecount=STRING|"4"
varname=STRING|"Folders"
varvalue=STRING|"D:\dest\folder1"
varvalue00000001=STRING|"D:\dest\folder2"
varvalue00000002=STRING|"D:\dest\folder3"
varvalue00000003=STRING|"D:\dest\folder4"
Name=STRING|"Text Loop"
_rt_variables_produced=STRING|"TargetFolder"
delimiter_no=STRING|"0"
destvar=STRING|"TargetFolder"
line0=STRING|"{Folders}"
quote_char=STRING|"0"
sourcetext=STRING|"1"
strict_delim=STRING|"1"
ActionID=STRING|"A_FILE_COPY"
Name=STRING|"Copy/Move File"
destdir=STRING|"{TargetFolder}"
f_count=STRING|"1"
file0=STRING|"{FileName}"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"0"
output=STRING|"0"
rename=STRING|"0"
renamemask=STRING|"*.*.new"
subdir=STRING|"0"
system=STRING|"1"
[\Comment]
s1=Copy one file to several folders
To copy many files to many folders use nested loops. Look at the next example. It copied all *.TXT files from folder d:\incoming to multiple folders
ExternalName=STRING|"Task90"
ID=INTEGER|-1032997912
Name=STRING|"Many files to multiple folders"
StepPause=INTEGER|0
Name=STRING|"Set variable ""SourceFolder"" with value ""D:\incoming"""
_rt_variables_produced=STRING|"SourceFolder"
varname=STRING|"SourceFolder"
varvalue=STRING|"D:\incoming"
Name=STRING|"File Loop"
date1=STRING|"20230618"
date2=STRING|"20230618"
destvar=STRING|"FileName"
DuringMinutes=STRING|"1"
file0=STRING|"{SourceFolder}\*.txt"
searchkind=STRING|"0"
sort=STRING|"0"
sortby=STRING|"0"
sortorder=STRING|"0"
subdirs=STRING|"0"
timesize=STRING|"0"
f_count=STRING|"1"
hidden=STRING|"1"
ifexists=STRING|"1"
move=STRING|"0"
output=STRING|"0"
rename=STRING|"0"
subdir=STRING|"0"
system=STRING|"1"
[\Comment]
s1=Copy all TXT files from d:\incoming to to several folders
anthonyystwarty
Hello, I'm going to study Variables, my knowledge is poor.. Você é excelente.
