search text file for certain text
VERDI
Post by VERDI »
Hi, Looking to monitor a folder and when a text file is created search it for specific text and if it is in the text file then send me an email.
Thanks for your help
See this example
Let me know if you have any questions.
This task read each new file and search the string specified string
Save the task into file and use menu Task | Import to import into RoboTask. Don't forget to enable the task after inporting.
