Custom Dialog "Cancel" pressed , default value
gremlin
Post by gremlin »
Hy,
how can I set a default value to all "Text Edit" fields, when "cancel" is pressed ?
I had 3 "Text Edit" fields, which need to be filled (laenge,breite,hoehe)
Thanks
Steven
Re: Custom Dialog "Cancel" pressed , default value
When you press "Cancel" you can assign some value that indicates that Cancel pressed.
You can analyze this value without stopping the task
If you want to use some default values you should specify default values in field configuration. You just should press OK or Enter key to confirm the values.
Look at my example below
CatID=INTEGER|327819672
ExternalName=STRING|"Task1435"
ID=INTEGER|-898468420
Name=STRING|"Custom Input Dialog Example"
ActionID=STRING|"A_CUSTOM_INPUT_DIALOG"
Name=STRING|"Custom Input Dialog"
default_value=STRING|"none"
dialog_caption=STRING|"Input Dialog"
dialog_height=STRING|"400"
dialog_width=STRING|"400"
field_count=STRING|"3"
field0=STRING|"{""type"":""CustomInputDialog"",""version"":""1.0"",""fieldGroups"":[{""caption"":""Field Properties"",""showCaption"":false,""fields"":[{""type"":""Simple Edit"",""labelText"":""Field Name:"",""name"":""name"",""value"":""value1""},{""type"":""Simple Edit"",""labelText"":""Caption:"",""name"":""labelText"",""value"":""Text Edit 1:""},{""type"":""Simple Edit"",""labelText"":""Default Value:"",""name"":""value"",""value"":""aaaa""},{""type"":""Checkbox"",""labelText"":""Password Input"",""name"":""passwordInput"",""value"":false},{""type"":""Checkbox"",""labelText"":""Numbers only"",""name"":""numbersOnly"",""value"":false},{""type"":""Checkbox"",""labelText"":""Required"",""name"":""required"",""value"":false}]}],""className"":""Text Edit"",""fieldName"":""value1""}"
field1=STRING|"{""type"":""CustomInputDialog"",""version"":""1.0"",""fieldGroups"":[{""caption"":""Field Properties"",""showCaption"":false,""fields"":[{""type"":""Simple Edit"",""labelText"":""Field Name:"",""name"":""name"",""value"":""value2""},{""type"":""Simple Edit"",""labelText"":""Caption:"",""name"":""labelText"",""value"":""Text Edit 2:""},{""type"":""Simple Edit"",""labelText"":""Default Value:"",""name"":""value"",""value"":""bbb""},{""type"":""Checkbox"",""labelText"":""Password Input"",""name"":""passwordInput"",""value"":false},{""type"":""Checkbox"",""labelText"":""Numbers only"",""name"":""numbersOnly"",""value"":false},{""type"":""Checkbox"",""labelText"":""Required"",""name"":""required"",""value"":false}]}],""className"":""Text Edit"",""fieldName"":""value2""}"
field2=STRING|"{""type"":""CustomInputDialog"",""version"":""1.0"",""fieldGroups"":[{""caption"":""Field Properties"",""showCaption"":false,""fields"":[{""type"":""Simple Edit"",""labelText"":""Field Name:"",""name"":""name"",""value"":""value3""},{""type"":""Simple Edit"",""labelText"":""Caption:"",""name"":""labelText"",""value"":""Text Edit 3:""},{""type"":""Simple Edit"",""labelText"":""Default Value:"",""name"":""value"",""value"":""ccc""},{""type"":""Checkbox"",""labelText"":""Password Input"",""name"":""passwordInput"",""value"":false},{""type"":""Checkbox"",""labelText"":""Numbers only"",""name"":""numbersOnly"",""value"":false},{""type"":""Checkbox"",""labelText"":""Required"",""name"":""required"",""value"":false}]}],""className"":""Text Edit"",""fieldName"":""value3""}"
grid_lines=STRING|"1"
label_column_width=STRING|"140"
save_to=STRING|"DialogResult"
stop_if_cancel=STRING|"0"
vertical_layout=STRING|"0"
value1=STRING|"none"
value2=STRING|"{DialogResult}"
Name=STRING|"Show ""Cancel pressed!!"""
icon=STRING|"3"
msg0=STRING|"Cancel pressed!!"
msg1=STRING|"No data"
msgcount=STRING|"2"
ActionID=STRING|"A_FLOW_ELSE"
Name=STRING|"Else"
Name=STRING|"Show ""Ok pressed"""
msg0=STRING|"Ok pressed"
msg1=STRING|"data: {DialogResult}"
msg2=STRING|"Value1 = {json:DialogResult.value1}"
msg3=STRING|"Value2 = {json:DialogResult.value2}"
msg4=STRING|"Value3 = {json:DialogResult.value3}"
msgcount=STRING|"5"
gremlin
Post by gremlin »
Ok, thank you. Now I understand how it works.
