Need help for a simple task
anthonyystwarty
Post by anthonyystwarty »
Hello, please help me: When creating a task for robotask to delete files, and when running the task the files are no longer in the folder, robotask says that the task was successfully executed....which command do I use for which robotask not complete task? I have a little difficulty, since robotask has no translation in my PT-BR language. can you help me again?
Re: Need help for a simple task
I don't understand a little...
The task is trying to delete some files, but the files do not exist. Correct?
What is the problem? This is normal situation and the task has finished successfully.
Maybe you should check for the existence of the files first
anthonyystwarty
Sorry for the delay to reply. I would like the task to display a runtime error, because the files were not deleted, and send me an email about the error. I do not know if i was clear.
Do you want an action to throw an error if it can't delete a file?
Ok I wrote this into our ToDo.
The action writes a warning only to the log
But now you can check the file existence after delete step.
If file does not exist then OK, if exists - you can generate the error (see Exit action) or send email
anthonyystwarty
I made a video showing, if the teste.txt file was no longer in the "test" folder and the option stop task execution in if error occurred, was checked, why didn't robotask stop the task? is there something i am doing wrong?
https://imgur.com/a/h3Mwps2
Initially the folder is empty
You are trying to delete a non-existent file
It's not an error. The file does not exist in the folder after the task. So, the operation is completed.
I think that you should check the file existence before delete operation and after.
Look at the example below. Save the text of the task to a file and use menu Task->Import to import the task into RoboTask.
Then you can see it in task editor.
CatID=INTEGER|799397369
ExternalName=STRING|"Task14"
ID=INTEGER|-2081236730
Name=STRING|"Delete file with checking"
Name=STRING|"Set variable ""filename"" with value ""C:\temp\test.txt"""
varname=STRING|"filename"
varvalue=STRING|"C:\temp\test.txt"
operator=STRING|"1"
value1=STRING|"{FileExists({FileName})}"
ActionID=STRING|"A_FLOW_EXIT"
Name=STRING|"Exit with error"
errorcode=STRING|"1"
errormessage=STRING|"File {FileName} does not exist"
mode=STRING|"1"
Name=STRING|"Delete File"
Count=STRING|"1"
deletedirs=STRING|"0"
deletereadonly=STRING|"1"
file0=STRING|"{FileName}"
hidden=STRING|"1"
subdir=STRING|"0"
system=STRING|"1"
ToRecycleBin=STRING|"0"
errormessage=STRING|"File {FileName} can not be deleted"
mode=STRING|"1"
anthonyystwarty
You are a genius Oleg, it worked perfectly! I did that and set variable C:\temp\*.*, and in delete file to include any file, and when running the task, because I didn't have any files in the folder, the task disabled, I'm your admirer. Thank you very much
