two questions
villanrl
two questions
Post by villanrl »
Hi.  Please point me in the right direction for the following...
1) is there repository of examples somewhere.
2) How would I code the following.... I'm using crystal reports to create a pdf file.  I use Send Keys to create the report but I want to start another one once the 'Exporting' window goes away.  I can't send any keystrokes because of a 'cancel' button on the exporting window.  I want to resume the script once the window has vanished.
3) lastly, I have a single text file that I want to watch.  I want to be alerted when it changes date.
Thanks in advance.  Russ V.
two questions
http://www.robotask.com/samples/
2) How would I code the following.... I'm using crystal reports to create a pdf file....
I think that crystal report have ActiveX library. You can control it from basic script. Please, refer to Crystal Report documentation.
See "File monitor" triggering event. You can specify file name instead of mask of files.
villanrl
two questions
Post by villanrl »
Cool.  Thanks.
