Accidentally Deleted Task
Zac
Post by Zac »
I'm reaching out here because I just made the biggest mistake on Robotask in a while where I was clicking keys on my keyboard and a prompt popped up and I clicked no without reading and the task that I was working on got deleted because I was careless, I wanting to know if there is a way to get it back at all or even pull up it's old log files so that I can remake the task off that because the task I created is super finicky and has over 1000+ actions in it to do a bunch of stuff and I really don't want to have to do this all over again if it's possible. Like is there a place where it would be moved to because I don't see it in my recycle bin on my desktop so I wanted to see if I was just looking in the wrong place for where it might be. Thank you!
Re: Accidentally Deleted Task
In your case, unfortunately, there is no way to recover the task because it was never saved.
You can save the task without closing the task editor. Use the "Save" button (see screenshot)
