Write Text File Action - ENTER, TAB, etc...
jpch
Post by jpch »
Is there a way to input Enter for a new line or Tab in the Write a Text File Action?
I tried with {ENTER} and {TAB} but it writes the text and doesn't create the new line or a tabbed space.
Thank you
Re: Write Text File Action - ENTER, TAB, etc...
If you want to write end of line symbols to text file use {EOL}. This is sequence of two symbols {Chr(13)}{Chr(10)} (carriage return and line feed)
To put TAB symbol use {Chr(9)}
TAB symbol has ASCII code 9
jpch
Post by jpch »
Thank you Oleg. It worked!
