Bug in dialog Custom Input Dialog
Re: Bug in dialog Custom Input Dialog
How did you get it???
sarnusch
Post by sarnusch »
Same here after adding "Text edit" (Version 9.5.0.1108 x64):
Screenshot 2023-03-16 083414.png (47.08 KiB) Viewed 32110 times
We have found the problem
This effect appears in RDP sessions only. Will be fixed today
Thank you for very fast report
Oh, I just wanted to reply what I did ;)
But, to be fair: nothing special. Just installed 9.5 and checked the new features. And yes, this is a RDP connection.
The problem has been fixed. Download and install fresh copy
sarnusch
Post by sarnusch »
Problem is solved with new version.
When installing it the following error came up (install with administrator rights):
Screenshot 2023-03-17 084933.png (29.15 KiB) Viewed 32090 times
After renaming the file the installation could be completed.
I have only one explanation:
Your antivirus locked this file or you opened this file in some program (for example some HEX editor)
RTP file is simple DLL with another extension
