Can I automate a tool??
Nidhi
Post by Nidhi »
 i would like to know if i can automate all the tasks of a webpage publishing tool using RoboTask.currently i can open the tool.After i open the tool i am supposed to open each of the folders and make some changes on those html pages inside the folder.Is it possible using RoboTask
Of course.
You can design such task with using the following actions:
- Send keystrokes
- Mouse actions ("move to object" and click)
Maybe you will need to insert a some pause between sending keystrokes and
mouse actions.
Also you can attach to the task "Hot key" triggering event
