Where is the task filter on the new V9.x UI?
I thought the new user interface should be better in terms of qol. Now the filter is gone I cannot easily filter enabled and disabled tasks. Or is there a new way to do this? Please bring this feature back if there isnt.
- Attachments
- image_2023-02-18_105004171.png (7.46 KiB) Viewed 12408 times
Re: Where is the task filter on the new V9.x UI?
Press Ctrl+F or use menu Tools->Find task in folder
Hmm I still don't see a way to filter enabled or disabled task with CTRL+F. The old V8.x versions are able to filter enabled/disabled tasks by clicking the "show all" drop down menu.
HAHAHA my bad I thought I pressed CTRL+F but I clicked the magnifying glass instead. Got it thank you
