Get Email IMAP or POP3
gremlin
Post by gremlin »
Hy,
I try to connect to my emailserver
POP3:outlook.office365.com 995 with SSL
or IMAP outlook.office365.com 993 with SSL
I get the error bad username / password. But these are correct.
The test with https://testconnectivity.microsoft.com/ can connect without any error.
Anyone use Robotask with Office365 and can help me ?
Thanks
Steven
Re: Get Email IMAP or POP3
You are testing the credentials the tool and you don't test the protocol itself to your own LAN. I think (but hey, assumption) that a firewall is blocking the POP and IMAP ports to your own internal lan or PC. We had a simular problem and after checking the firewall, it was solved.
gremlin
Post by gremlin »
Hy,
thanks for a possible source of error.
I had disabled the firewall, but the problem still there.
When Itest with other Emailsoftware, it works fine.
Yesterday I had contact with microsoft team and he told me the following:
According to the specialist department, your imap is deactivated for basic authentication and can no longer be activated. All third-party apps should support Modern authentication and TLS1.2.
So, Robotask can use TLS1.2 but I don´t know if it support modern authentication ?
Thanks
Steven
gremlin
Post by gremlin »
Hy,
no one use Robotask and Microsoft365 with IMAP or POP ?
How you get working ?
I got same error all the time
Thanks
Steven
vovaz
Post by vovaz »
Hey,
I have the same problem, can't login IMAP step to office365
Office365 disabled classic authorization for business accounts.
We will add OAuth2 authorization (beta version) to email actions in next release
