how to mathmatically increment a variable by another variable
mhamlett101
Post by mhamlett101 »
{Add("{Line(3)}","{vPPAIQTotal}")}
trying to increment a variable by an amount
doing a Set Variable action
not totaling
looping thru a text file, extracting a comma delimited field
the totaling the $'s on each line to a grand total
Re: how to mathmatically increment a variable by another variable
It seems we solved this problem
Probably you forgot about the option Expand value : https://robotask.com/help/index.html?setvariable.htm
If you want to set the value of a variable and use the same variable in an expression, this option is required.
